** EK MONOBLOCKS **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Our pals at EK Water Blocks have released some very special looking all in one blocks. This is a total motherboard cooling solution designed to offer epic flow, cooling performance as well as looking perfect.
The monoblock design will hopefully be a success and filter down to less mental boards over time.
To celebrate, Overclockers UK Tech Labs have launched an all in one bundle featuring a board with your choice of CPU and Monoblock.
Pre orders are available now and stock should be here very soon!
OcUK Tech Labs - Asus Rampage IV Extreme Black Edition R4BE Monoblock - EK Ultimate Cooling Solution - Intel i7 From £723.92 inc VAT
Assembled in house by Expert OcUK Technicians
The world's most powerful and versitile overclocking motherboard. The addition of the Ultra High end waterblock kit from a selection of premium manufacturers make this the ultimate motherboard choice.
Maximise your Overclocking potential and system lifespan with this custom cooling solution providing incredible running temperatures as well as mind-blowing aesthetics.
Every Watercooled motherboard sold by Overclockers UK is assembled by an Expert OcUK technician and tested for quality assurance before it ships to the customer.
This Monoblock version includes options from the new Monoblock design by EKWB. This replaces the requirement for a CPU block and gives the user ultimate control over their system. We pre install the CPU of your choice and the monoblock for ultimate cooling.
WARNING! Potential long wait for stock from pre-order due to massively high demand.
Continuing ROG’s legendary overclocking reputation, ASUS is glad to launch the first X79-based ROG motherboard - the RAMPAGE IV EXTREME. It aims to fulfill PC enthusiasts’ needs towards greater performance. The R4E motherboard supports the latest LGA 2011 socket for 2nd Gen Intel® Core i7 and Extreme Edition Processors, and it newly launches some revolutionary overclocking features. With record breaking excellence, it’s time to rock the overclocking world again!
RAMPAGE IV EXTREME is presented with a bunch of hardware upgrades baring the latest utilities designed to unleash the full OC potential and push systems to their limit. The R4E features Extreme Engine Digi+ II offering optimum power efficiency with premium components and intelligent digital design. Built-in finest Japan-made Black Metallic Capacitors offer +20% low temperature endurance and 5X longer lifetime usage.
Most notable is the supplied OC Key which provides an on-screen graphical overlay without the need for extra software on your monitor, allowing you to tweak and monitor your system’s settings in real-time. The Subzero Sense even offers as precise subzero degree measurement as costly thermometers, saving users money while enjoying the same benefits. For PC enthusiasts, there is one thing they don’t wanna miss - the accurate and effortless VGA overvolting way. No need to solder and blindly tweak the tiny resistors, the VGA Hotwire makes VGA overvolting quick and easy via interface such as OC Key, TurboV EVO, and UEFI BIOS. Last but not the least, don’t rush to junk your expensive LGA1366 cooler. With X-Socket, switch out the LGA2011 pad for a 1366 one and you can get more life out of your previous CPU cooler!
With a gorgeous design, great performance and revolutionary features, overclockers will no doubt lust after the RAMPAGE IV EXTREME.
From £723.92 inc VAT.
ORDER NOW
Blocks available for existing owners:
EK Water Blocks EK-FB ASUS R4BE Monoblock - Acetal+Nickel (Original CSQ) @ £135.95 inc VAT
Only £135.95 inc VAT.
ORDER NOW
EK Water Blocks EK-FB ASUS R4BE Monoblock - Nickel (Original CSQ) @ £135.95 inc VAT
ORDER NOW
EK Water Blocks EK-FB ASUS R4BE Monoblock - Acetal+Nickel @ £135.95 inc VAT
ORDER NOW
EK Water Blocks EK-FB ASUS R4BE Monoblock - Nickel @ £135.95 inc VAT
ORDER NOW
i doubt it.
I hope that EK start offering this on more mainstream boards though.
would be really good to have this become a thing.
My only annoyance with this is that it's then the same as full cover waterblocks in that you can't re-use them on another board.
That said I do prefer full cover waterblocks over gpu-only blocks, but generally as you can't use a gpu-only block with the stock cooling for everything else, which you can with a motherboard.
They look good though.
Id have expected these to represent a bit of a saving over the individual blocks tbh.
I suppose these have the advantage of being a cleaner install due to less pipes and you save on 4 fittings off the top of my head.
Does look good though.
