- 19 Jan 2003
- west sussex
Well when working they are very good, I have a predator 360 cooling my CPU only, and then bought a predator 280 to cool GPU only, its been running perfect for 3 weeks and then yesterday I had some bubbles in the 280 system, I thought fine, I will top up. finished toping up and all good once again.
Then this evening I switched on to find more bubbles in the system, which I thought strange as I only toped up the 280 yesterday, on closer inspection the pump fitting had a drip. which is kind of weird as its been fine and not moved for 3 weeks plus.
after removing the 280 and inspecting the pump fitting I found the plastic to have hair line cracks around where the fitting screws into the pump. the wall thickness of the plastic tube coming from the pump where the fitting screws into is to thin. obviously over the period of the 3 weeks where the fitting is screwed into the pump the thread walls developed hair line cracks and of course started to leak as it relies on an O ring to seal to the end of the outlet of pump, once the hairline cracks appear water seeps past the thread and drips.
Now the dilemma, Parts and RMA possibilities on the 22nd of December wanting to use my PC over the holidays. Only one choice really and that's fix it. so I found me some solid tubing to go over outlet of the pump which left a gap of 3mm all around the original outlet.
from there I filled the gap with chemical metal, so I now have a nice thick wall to the outlet of the pump, once at the same height you can file flat so you get a nice seal for the Oring on a decent flat surface that wont leak and you can tighten up nicely.
predator 280 refilled and refitted and leak free from that fitting connected to the pump. I am considering doing the same thing to the 360 predator to avoid this hair line cracking which these pumps seem to suffer from.
anyway fixed, leak free, much stronger and I can now use my PC
