31 Dec 2013 at 16:40 #1 Jokester Jokester Don Joined 7 Aug 2003 Posts 45,100 Location Aberdeenshire Does anyone have one and know the internal flow setup? I need to blank two off (middle two) and don't know if it's parallel or serial blanks I need.
31 Dec 2013 at 19:09 #2 diogenese diogenese Soldato Joined 18 Oct 2002 Posts 3,023 Location Temuka, New Zealand http://www.ekwb.com/shop/EK-IM/EK-IM-3831109856734.pdf I reckon you need the parallel blanks, if you used serial all your flow would bypass the blocks. Last edited: 31 Dec 2013
31 Dec 2013 at 19:39 #3 Jokester Jokester Don OP Joined 7 Aug 2003 Posts 45,100 Location Aberdeenshire That looks right, think the newer style Terminal blocks will be identical. Cheers.
31 Dec 2013 at 21:15 #4 Silent_Scone Silent_Scone Soldato Joined 5 Sep 2011 Posts 12,886 Location Surrey Are their newer bridges than those in the pdf available? Last edited: 31 Dec 2013
31 Dec 2013 at 22:01 #5 diogenese diogenese Soldato Joined 18 Oct 2002 Posts 3,023 Location Temuka, New Zealand I think with their newer blocks you can use acrylic pipe and do series or parallel as you like.
31 Dec 2013 at 22:38 #6 Jokester Jokester Don OP Joined 7 Aug 2003 Posts 45,100 Location Aberdeenshire The terminal blocks are the current version and feature a flattened flow path compared to older bridge style which were simply round.
1 Jan 2014 at 00:27 #7 diogenese diogenese Soldato Joined 18 Oct 2002 Posts 3,023 Location Temuka, New Zealand I know the older CSQ bridges don't align with the newer blocks...
1 Jan 2014 at 00:41 #8 Jokester Jokester Don OP Joined 7 Aug 2003 Posts 45,100 Location Aberdeenshire It's the Termin range you need for the newer blocks.
