- 22 Oct 2020
Hi folks,
Does anyone have any experience with the EK-Quantum Kinetic FLT 360 D5 Reservoir and the Asus Helios case?
I'm currently thinking through my first custom loop with a 5900x, and unsure if there's enough clearance between the GPU first PCI-E slot, and the D5 Reservoir with it being mounted to the PSU Shroud.
For reference the below is my planned build(Still in early planning stages);
Item | Qnty
EK-CoolStream SE360 (Slim Tripple) | 2
EK-Quantum Torque HDC 12 - Black | 1
EK-Quantum Torque Color Ring 10-Pack HDC 12 - Black | 1
EK-CryoFuel Solid Cloud White (Conc. 250mL) | 2
EK-ATX Bridging Plug (24 pin) | 1
EK-Cable Pump testing adapter | 1
EK-Cable Y-Splitter 3-Fan PWM (10cm) | 2
EK-HD Tube D.I.Y. Kit 10&12mm | 1
EK-Quantum Momentum ROG Strix X570-E D-RGB - Plexi | 1
EK-Quantum Kinetic FLT 360 D5 PWM D-RGB - Plexi | 1
EK-HD Tube 10/14mm 500mm (2pcs) | 2
Some casual build notes:
Item | Qnty
- It will be just a CPU/Motherboard coverage on the block, I may go for GPU water cooling in the far-out future, but for convenience, I want to keep the GPU on air for a while.
- Currently reading about the most convenient method of installing a drain method that doesn't stick out like a sore thumb.
