- 15 Feb 2013
- Edinburgh
Hey,
Money and fate have been cruel to me so my PC Build plans have been knocked down a few pegs.
I was planning on buying an EK Supremacy for a new build, but the new Hardware budget sort of fell through but from their site I see that the block is compatible with my current i7 920.
*Light bulb noise*
Is it an alright Idea to use the budget I'd set aside for Watercooling the next build on my current pc?
And then use the res&rads&pump etc etc on my next build, and reusing the CPU block, I hear people talk about how they re-use CPU blocks( I've never had the chance)
So the Point I suppose is can the EK-Supremacy be reused from a i7 920 (1366) on newer CPU (that's currently out) without much hassle?
Has anyone done it before? Or will I come up against problems?
Thanks
*Light bulb noise*
Thanks
