I been spending most of the day setting up my first watercooling build. It is a CPU only loop, with a modified polo heatercore, a eheim 1048 pump and a EK supreme waterblock; all with 1/2" tubing.
To cut a long story short, i spent about 2 hours trying rid the system of air untill the pump stopped making a din. No luck!
I have since played in the sink and have found that this waterblock alone is making the pump winge. The pump is fine on its own (good flow rate), but the flow rate drops heavily when attached to the block (and the pump makes a rattling noise).
I have tried everything i can think of, dissembling the block to check its clean, using the pump to push and pull water through it(not at the same time!!).
I know the EK supreme is a bit flow constraining, but surely this shouldnt happen?
Im out of ideas and this is really annoying me!
Any help would be greatly appreciated!
Charlie
Charlie
