EK Supreme HF fitting on RIVE
24 Aug 2007
Hi,
I'm trying to work out why my temps are not so great on what i think is a very good watercooling setup, and i'm wondering about how my waterblock is mounted
I can't remember seeing instructions on how to fit my block so wondered if anyone has instructions
I'm may well have done it fine, but i just want to be sure
thanks
Averaging 70+ at 4.5ghz (1.35v) using Prime, with an Alphacool Monsta 360 x 80mm radiator and an EK 240mm radiator. AP-15 fans throughout and an Ek DCP 4.0 pump
Should be better surely?
Just noticed this
http://www.ekwb.com/shop/EK-IM/EK-IM-3830046990181.pdf
And i'm pretty sure mine wasn't installed the same, i had a rectangular backplate that i fitted, i didn't just mount the waterblock to the backplate thats already fitted? Unless i'm reading the diagrams wrong!
I think the rive has holes to fit the 1366 backplate as well as the standard 2011 fitting that screws directly into the socket.
