ek supremecy evo leaking
24 Mar 2004
kintyre
as above the full copper block,the leak is on the bottom /cpu side of the block,seems to be coming from where the retention bracket is sandwiched between the two pieces of copper.anyone seen this before?
Do you have a picture of the leakage?
It might help the EK rep here to diagnose for you as well.
unfortunatly not mate,loop now drained and block disconected.the block is only two months old so i didnt want to open it up ,just took it out..
Strip it down and check the O rings as it sounds that one is not seted properly, been piched or has failed. Clean it up, reseat the O rings and retighten the 4 screws. Put it in a loop by itself and test it for several hours.
not opened the block ,also my usualy solid graphics graphics card gave up the ghost last week,maybe too much of a coincedence.have i got any come back if this is the case?(not at this time saying it is just wondering)
Were the graphics cards watercooled and in the same loop? I ask as you may have some form of restriction in the loop, possibly coolant buildup in the cpu blocks jetplate/fins. Do you use a coloured coolant by any chance?
i have not had this block open thats why i was reluctant to open it in the first place but i shall do as you say.@ jeffib only distilled water and bionuke in loop mate.:)
not that i noticed last time will drain and check again after dinner
[/URL][/IMG] edit one thing i did notice though was that one of the screws was discoloured half way down the thread
