- 6 Jan 2013
- Rollergirl
I'm trying to apply the 0.5mm pads to the ram blocks. However, when I peel the blue plastic film off it feels like there's a thin layer of clear film left. It feels different on both sides, but if I try to take the second "film" off, the pad starts breaking up.
I've fit loads of blocks before and never seen this, is it a new design of pad?
EDIT:
Response from EK:
EDIT:
Response from EK:
New thermal pads are sticky on one of the sides and not sticky on the other side. The plastic film (under the blue) has to stay in place.
New thermal pads also perform better compared to the old, grey pads.
