ek titan x waterblock compatability
Going to say probably not, gm200 is 650mm^2 while gp102 is 471mm^2
They look superficially similar but it's pretty likely you would run into clearance issues.
Waterblock for a reference 1080ti should work according to the ek compatibility chart and should be pretty common.
