Hi Guys
Seems we are first to market with this one also.
Order placed with EK Water Blocks this morning for hundreds of 980 waterblocks.
We have the full range of EKWB 980 Blocks available to pre order on our site right now.
EK-FC980 GTX is a high performance full-cover water block for nVidia reference (NVA-1G401) design GeForce GTX 980 series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC980 GTX water block features a central inlet split-flow cooling engine design for best possible cooling performance, which also works flawlessly with reversed water flow without adversely affecting the cooling performance. Moreover, such design offers great hydraulic perfromance allowing this product to be used in liquid cooling systems using weaker water pumps.
Base is made of electrolytic copper while the top is made of quality acrylic material. The top also features two pre-drilled slots for 3mm LED diodes. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M2.5 DIN7985 screws and allows for re-use of the original NVIDIA backplate.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC980 GTX Backplate - Black or Nickel) which improves the looks of your graphics cards and also provide some passive cooling to the circuit board VRM section.
G1/4" threaded fittings can be used on both sides of the FC terminal. Up to four EK-FC980 GTX water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
EK-FC980 GTX series product is also the choice of EVGA for their factory liquid cooled NVIDIA GeForce GTX 980 HydroCopper series graphics cards.
Enclosed:
- EK-FC980 GTX series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
- thermal grease EK-TIM Ectotherm (1g)
Made in Slovenia - Europe!
EK Water Blocks EK-FC980 GTX @ £79.99 inc VAT
Only £79.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC980 GTX - Acetal @ £79.99 inc VAT
ORDER NOW
EK Water Blocks EK-FC980 GTX - Acetal+Nickel @ £89.99 inc VAT
Only £89.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC980 GTX - Nickel @ £89.99 inc VAT
ORDER NOW
EK Water Blocks EK-FC980 GTX - Nickel (Original CSQ) @ £89.99 inc VAT
ORDER NOW
OcUK Tech Labs H2O Custom GeForce GTX 980 4096MB GDDR5 PCI-Express Graphics Card From £539.99 inc VAT
The OcUK Tech Lab H2O Custom GeForce GTX 980 combines the most overclockable single GPU card available with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
With a choice of the finest cooling solutions from EK Water Blocks, this card looks incredible no matter what finish you choose.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of IC Diamond is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The 980 operates at extremely low temperatures and has massive overclocking headroom out of the box, but the addition of a waterblock really allows the user to push the card to its limits easily and safely.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
From £539.99 inc VAT.
ORDER NOW
Enclosed:
- thermal pads
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
ORDER NOW
