** EK WATER BLOCKS - PREDATOR PRE FILLED GRAPHICS CARD WATER BLOCKS **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Due to popular demand we have stock incoming of the pre filled water block range from EK that are designed to work with their Predator all in one watercooling units.
These clip straight into the Predator 360 Water Cooling unit using quick disconnectors which dont spill any fluid.
This is the easiest way to properly watercool your graphics card using a predator unit.
We are also offering a range of pre assembled units in our ocuk tech labs range.
EK Water Blocks EK-FC970 GTX Strix - Acetal & Nickel - Predator Pre Filled @ £105.95 inc VAT
Only £105.95 inc VAT.
ORDER NOW
EK Water Blocks EK-FC970 GTX - Acetal - Predator Pre Filled @ £94.99 inc VAT
Only £94.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC980 GTX - Acetal - Predator Pre Filled @ £101.99 inc VAT
Only £101.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC Titan X & 980 Ti - Acetal - Predator Pre Filled @ £104.99 inc VAT
Only £104.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC980 GTX Ti WF3 - Acetal & Nickel - Predator Pre Filled @ £114.95 inc VAT
Only £114.95 inc VAT.
ORDER NOW
EK Water Blocks EK-FC980 GTX Ti Strix - Acetal & Nickel - Predator Pre Filled @ £124.99 inc VAT
Only £124.99 inc VAT.
ORDER NOW
OcUK Tech Labs EK-FC 980 GTX Ti - Acetal - Predator Pre Filled Watercooled Graphics Card @ £634.99 inc VAT
Only £634.99 inc VAT.
ORDER NOW
OcUK Tech Labs EK-FC Titan X - Acetal - Predator Pre Filled Watercooled Graphics Card @ £974.95 inc VAT
Only £974.95 inc VAT.
ORDER NOW
OcUK Tech Labs EK-FC980 GTX Ti WF3 - Acetal & Nickel - Predator Pre Filled Watercooled Graphics Card @ £674.99 inc VAT
Only £674.99 inc VAT.
ORDER NOW
OcUK Tech Labs EK-FC980 GTX Ti Strix OC - Acetal & Nickel - Predator Pre Filled Watercooled Graphics Card @ £744.95 inc VAT
Only £744.95 inc VAT.
ORDER NOW
OcUK Tech Labs EK-FC980 GTX Ti Strix - Acetal & Nickel - Predator Pre Filled Watercooled Graphics Card @ £689.99 inc VAT
Only £689.99 inc VAT.
ORDER NOW
CHECK OUT THE FULL OCUK WATERCOOLING RANGE HERE
CHECK OUT THE FULL RANGE OF EK WATER BLOCKS PRODUCTS AT OVERCLOCKERS UK HERE
Nice. I've been waiting for this so that I can continue my project log!
One question rjk.
What about the TF5 variant of the block (for my MSI gaming 6 card)?
You just had me triple checking my work then!!!
I had set it up but missed it when I made the others live.
It will be available to pre order in about 10 minutes.
Awesome! Expect a pre order from me later today then!
I know that I am still shy of the free shipping (need to wait until May for my 1 year forum anniversary). Given that the build is being documented in the project log section, any chances of sorting a brother out? :p
Cant see why not. Call up to order and tell the sales team I said it was cool :)
be sure to post up some images when you got it!
Well then it looks like my credit card will be taking a beating soon. My plan has been to buy a new case, the predator 360 and use a GPU block with it. I had reservations about the GPU block as its been a long time since i've dismantled a GPU and my health has deteriorated since then. Thankfully now this means i'll just be able to buy the card pre-built and not have to worry, I love you OCUK!
plenty of room on there to make it fit into bigger cases. plus the rotary fittings really help a lot
Also, the tubing on the Predator is pretty generous so when you QDC the CPU tubing to bring the GPU into the loop you are gaining a fair amount of slack to work with.
Thanks again for sorting me out Rich. 980ti TF5 block now ordered. It's going to be nice to get rid of the G10/H55 cooling from the GPU :D
I'll certainly post some DSLR shots of the upgrade.
no worries at all. glad we could help.
ETA for the block will be the back end of next week at a guess.
The Predator radiators have a fixed CPU block, yes? will a Predator 360 rad cope with CPU and two 980Ti's or can I mix and match?
Andi.
Andi.
From the review temps I think it'll cope, even if the temps aren't what you'd call 'low'
But they'll be a hell of a lot quieter than air and probably lower temps!!
The pump is 6w in the pred. From feedback from guys smarter than me, you may find that an upgrade to the pump (which can be done) may be relevant if you have 2x980ti's. You could also add a second rad into the loop.
Quiet is good, I did my first water cool system because of noise.
Will the 980Ti plates support an EVGA SC ACX?
What ETA for the 36 rad?
Andi.
