Hi Guys
On order now and available for you guys to pre order, we have some sensational offerings from EK Water Blocks that will allow you to get the very best out of your VGA.
In the Red Corner,
We have EK Water Blocks EK-FC R9-290X Water Blocks
These come in two flavours and styles with a CSQ style which will be listed very soon.
I can see these being very popular
In the Green Corner,
The new EK Water Blocks EK-FC780 GTX Classified.
Now the ultimate enthusiast VGA card can benefit from a cooling solution deserving of this card.
In the Red Corner,
EK Water Blocks EK-FC R9-290X Backplate - Black @ £21.95 inc VAT
EK-FC R9-290X Backplate is a CNC machined retention backplate made from black anodized aluminum for EK-FC R9-290X series water blocks.
Backplate cover the whole lenght of graphics cards PCB, serves as an aesthetic add-on and also provides passive cooling for the VRM (Voltage Regulation Module) on the backside of the circuit board.
This backplate is guaranteed to be compatible only with reference PCB design Radeon R9 290X series graphics card in combination with any EK-FC R9-290X series water block.
No other water blocks are officially supported! Please check our Cooling Configurator for detailed compatibility list!
Enclosed:
- EK-FC R9-290X Backplate - Black
- mounting mechanism
- thermal pads
Made in Slovenia - Europe
Please note:
- The backplate does not serve as a standalone unit
Only £21.95 inc VAT.
ORDER NOW
EK Water Blocks EK-FC R9-290X @ £79.99 inc VAT
EK-FC R9-290X is a high performance full-cover water block for AMD reference design Radeon R9 290X and -290 graphics card. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC R9-290X water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps. The cooling engine now uses refined, 0.6mm wide microchannel structure to even further improve the heat transfer.
Base is made of electrolytic copper while the top is made of quality acrylic glass material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC R9-290X Backplate - Black) which improves the looks of your graphics cards and also provide some passive cooling to the VRM section.
G1/4" threaded fittings can be used on both sides of the FC terminal. Flow orientation doesn't matter and is thus not prescribed.
Up to four EK-FC R9-290X water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC R9-290X series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
- thermal grease EK-TIM Ectotherm (1g)
Made in Slovenia - Europe!
Only £79.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC R9-290X - Acetal @ £79.99 inc VAT
Base is made of electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
ORDER NOW
EK Water Blocks EK-FC R9-290X - Nickel @ £87.95 inc VAT
Base is made of nickel plated electrolytic copper while the top is made of quality acrylic glass material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
Only £87.95 inc VAT.
ORDER NOW
EK Water Blocks EK-FC R9-290X - Acetal+Nickel @ £89.99 inc VAT
Base is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
Only £89.99 inc VAT.
ORDER NOW
Enclosed:
- thermal pads
Please note:
ORDER NOW
Enclosed:
- thermal pads
ORDER NOW
Enclosed:
- thermal pads
ORDER NOW
Enclosed:
- thermal pads
ORDER NOW
Enclosed:
- thermal pads
ORDER NOW
EK Water Blocks EK-FC780 GTX Classified Backplate - Black @ £21.95 inc VAT
EK-FC780 GTX Classy Backplate is a CNC machined retention backplate made from black anodized aluminum for EK-FC780 GTX Classy series water blocks.
This backplate is guaranteed to be compatible only with EVGA custom Classified PCB design GeForce GTX 780 series graphics card in combination with any EK-FC780 GTX Classy series water block.
Enclosed:
- EK-FC780 GTX Classy Backplate - Black
- thermal pads
Please note:
ORDER NOW
EK Water Blocks EK-FC780 GTX Classified - Nickel @ £89.99 inc VAT
EK-FC780 GTX Classy is a high performance full-cover water block engineered specifically for EVGA design GTX 780 Classified series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC780 GTX Classy water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of nickel plated electrolytic copper while the top is made of quality acrylic glass material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC780 GTX Classy Backplate - Black) which improves the looks of your graphics cards and also provide some passive cooling to the VRM section.
Up to four EK-FC780 GTX Classy water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC780 GTX Classy series water block
- thermal pads
ORDER NOW
EK Water Blocks EK-FC780 GTX Classified - Acetal+Nickel @ £89.99 inc VAT
Base is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
ORDER NOW
Enclosed:
- thermal pads
Please note:
ORDER NOW
Enclosed:
- thermal pads
ORDER NOW
Enclosed:
- thermal pads
ORDER NOW
