18 May 2011 at 11:06 #1 andicole0 andicole0 Soldato Joined 12 Sep 2005 Posts 6,497 Location Grundisburgh I have two GTX 480s with EK water blocks currently connected with tube. Is there a way to add a block to hold the two together? Andi.
18 May 2011 at 11:22 #2 SeraphX SeraphX Soldato Joined 7 Jun 2010 Posts 7,166 Location Sussex you mean something like the EK-FC Bridge dual serial? http://www.ekwaterblocks.com/shop/b...onnection-parts/ek-fc-bridge-dual-serial.html
18 May 2011 at 11:24 #3 OLDPHART OLDPHART Soldato Joined 19 Jun 2004 Posts 6,521 Location n/east-the toon andicole0 said: I have two GTX 480s with EK water blocks currently connected with tube. Is there a way to add a block to hold the two together? Andi. Click to expand... Google this > Thread Varible Single Slot SLI & CrossFire VID Fitting, you can get different lenghts, this adapter is used in stead of tubing.
