Hey Guys
Just to inform you that we now carry stock of EK Waterblocks that use the EN Nickel Plating method.
As many of you are aware, EK recently had an issue where some of their nickel plated products suffered from flaking, this new method of nickel plating is a much more expensive process and has proved to be much more hard wearing.
We are aiming to refresh our catalogue with the full range of EN Nickel Plated products from EK as availability increases.
EK Supreme LTX CPU Waterblock - Nickel Plexi **EN Nickel Plated** @ £32.98 inc VAT
EK-Supreme LTX water block for all socket CPU's has been designed for the hardest enthusiast user. The LT (Light) version has beed designed to lower the production costs and offer EK quality branded CPU water block at the best price.
The base plate is made of nickel plated electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of quality Acrylic material.
The EK-Supreme LTX cooling engine uses fin design. The water accelerates through 46 very thin channels, which gives extreme cooling surface. The copper base is also very thin, which gives very short distance for temperature to transfer from CPU to water.
Supported sockets:
Processor compatibility:
- Intel Socket 775,
- Intel 1366 socket
- Intel 1156 socket
Only £32.98 inc VAT.
ORDER NOW
EK Supreme LTX CPU Waterblock - Nickel Acetal **EN Nickel Plated** @ £32.99 inc VAT
EK-Supreme LTX water block for all CPU socket is a successor of Supreme LT and designed for the hardest enthusiast user. The LTX (Light xtreme) version has been designed to lower the production costs and offer EK quality branded CPU water block at the best price.
The base plate is made of nickel plated electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of quality POM Acetal material.
The EK-Supreme LTX cooling engine uses fin design. The water accelerates through 46 very thin channels, which gives extreme cooling surface. The copper base is also very thin, which gives very short distance for temperature to transfer from CPU to water. The main improvement made compared to Supreme LT version is that LTX has deeper channels (0,5mm deeper), therefore allows greater flow and better performance.
Supported sockets:
- Intel 775 socket
- Intel 1366 socket
- Intel 1156 socket
- Intel 1155 socket
Only £32.99 inc VAT.
ORDER NOW
Supported sockets:
- Intel Socket 775,
- Intel 1366 socket
- Intel 1156 socket
ORDER NOW
Supported sockets:
- Intel 775 socket
- Intel 1366 socket
- Intel 1156 socket
- Intel 1155 socket
ORDER NOW
