4 Oct 2011 at 13:36 #61 rjk rjk Caporegime OP Joined 8 Aug 2007 Posts 25,381 EK have managed to fulfil orders for some kits. all 240 and 360 HF kit pre-orders should be fulfilled. however, stock availability of the LT kits are still in restraint from EK.
6 Oct 2011 at 23:58 #62 buzzlightweight buzzlightweight Associate Joined 22 Aug 2010 Posts 2,213 Location In My Command Center just finished my build with these kits. links in sig
7 Oct 2011 at 21:41 #64 Miidget Miidget Associate Joined 7 Oct 2011 Posts 280 Location South-East England With the different systems is there a massive difference between the 120,240 and 360 kits? and does it get increasingly noisy?
7 Oct 2011 at 21:58 #65 GoogalyMoogaly GoogalyMoogaly Soldato Joined 29 Aug 2010 Posts 7,865 Location Cornwall Miidget said: With the different systems is there a massive difference between the 120,240 and 360 kits? and does it get increasingly noisy? Click to expand... If anything it should get quieter as in theory you could probably run the fans slower.
8 Oct 2011 at 09:58 #66 buzzlightweight buzzlightweight Associate Joined 22 Aug 2010 Posts 2,213 Location In My Command Center GoogalyMoogaly said: If anything it should get quieter as in theory you could probably run the fans slower. Click to expand... if you do not have a pump controller then the pump will hum, if you do not have a fan controller those fans are loud!
