EK X3M drgb 120er Fans and Aquacomputer Octo compatibility
7 Oct 2015
Heard mixed opinions in terms of power.
are both the above compatible with one another in terms of pwm control and control of rgb lighting?
Thanks
I had an octo that had only 5 fans- all non rgb and 2 aqua computer rgb strips on it and it surged and fused so I would be careful with what you use
Hmm thanks for the heads up. What controller aside from the octo would you recommend to control 6 ek X3M rgb fans?
Preferably not ek’s own fan controller as I heard their software control sucks
