EK XRES 140
19 Nov 2011
Hi Fellas,
Just a quick question, just bought a EK XRES 140 for my D5 pump.
Currently all of my fittings are XSPC, would the XSPC fittings work just fine with this res, and are any of you guys using them with it?
Many thanks in advance!
As long as they use G1/4 threads they should fit fine, I've used Primochill ones and they worked well so there's no reason why XSPC fittings shouldn't work.
It was the 5mm fitting note in the packaging which made me wonder the XSPC ones are bang on pretty much.
I'm still in the planning stages at the moment. :p
