Hi Guys
We have the awesome looking new block from EKWB coming soon
They have confirmed to me that this block is compatible with the current GTX 780 card as well as the upcoming 780 Ti version.
We will offer a Tech Labs HOF Ti also.
All white KFA cards are exclusive to OcUK in Europe so this is a truly unique product.
I think you will all agree that this is one of the nicest looking water blocks that EK have ever produced.
and on the white card, it looks even better!
EK Water Blocks EK-FC780 GTX HOF - White Acetal+Nickel @ £89.99 inc VAT
EK-FC780 GTX HOF is a high performance full-cover water block for engineered specifically for Galaxy / KFA² design GTX 780 (Ti) Hall Of Fame series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC780 GTX HOF water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of nickel plated electrolytic copper while the top is made of quality white POM Acetal material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
G1/4" threaded fittings can be used on both sides of the FC terminal. Flow orientation doesn't matter and is thus not prescribed.
Up to four EK-FC780 GTX HOF water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity (such as EK-HD Tube & Adapter System). Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC780 GTX HOF series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
- thermal grease EK-TIM Ectotherm (1g)
Made in Slovenia - Europe!
PLEASE NOTE:
- Fittings are not included! Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
- Water block ports does align with EK-FC Titan (SE), EK-FC780 GTX Jetstream and EK-FC780 GTX Ti series water blocks.
Only £89.99 inc VAT.
ORDER NOW
OcUK Tech Labs H2O Custom KFA GTX 780 Hall OF Fame - White 3072MB Watercooled Graphics Card @ £549.95 inc VAT
The OcUK Tech Lab H2O GTX 780 HOF combines the most overclockable single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
We took the worlds fastest GTX 780 and Watercooled it!
Exclusive to Overclockers UK we have the worlds fastest GTX 780 - the KFA2 GTX 780 LTD OC or better known to some as the Galaxy Hall of Fame. With many premium and unique features such as Hyper Boost Hardware for maximum clock speeds and cooling. The first GTX 780 to use hybrid heat pipe plus vapor chamber cooling for near silent operation yet very low temperatures. Built and designed using 8+2 phase digital power, premium POSCAP and MLCC capacitors all based on a stunning white looking PCB. If you want the fastest GTX 780 on the market and one which looks different to any other, then look no further!
Features:-
- Hyper Boost hardware overdrive switch supercharges your core clocks
- World’s fastest air-cooled GTX 780 with 1058Mhz boost clock
- 1st GTX 780 with hybrid heat pipe + vapor chamber cooling
- Premium POSCAP and MLCC capacitors
- Winner of multiple overclock world records
- 8+2 phase digital power
- Voltage read points
- Custom white PCB
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 1006 MHz
- Core Boost Clock: 1058 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £549.95 inc VAT.
ORDER NOW
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
Features:-
- Custom white PCB
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
