EKWB MX vs EVO - Supremacy CPU blocks?
11 Sep 2013
Heya,
I was all set to get a Supremacy EVO CSQ (either standard or Nickel), but then discovered the Supremacy MX...
Reviews would have me believe the MX is exactly the same as the EVO in terms of performance, just cheaper because it doesn't include loads of different mounts. I just have to make sure I get the 1155 compatible one...
Do the OCUK denizens concur?
EK Luc?
Would I be better off getting the Nickel CSQ EVO over either the normal EVO or this MX one?
Cheers,
Tasky.
