Elastix/Asterisk help
16 Mar 2004
Oxford
Not sure where is best for this, but I guess as it's server related this is probably closest.
I've also posted this onto the Elastix forum, but wondered if anyone on here can help:
I'm running Elastix 2.5.0 which all works well using SIP extensions and goes through a FXO card on a Wildcard TDM400P REV E/F Board 5. I've also setup a SIP trunk as a second line. This all works as it should and I can make and receive calls to and from both PSTN & SIP lines.
I've recently added a FXS card to the system and I've got this setup as a DAHDI extension and I can receive calls (internal and external), however when I try to make a call (internal or external) I get a busy tone. Can anyone help, I'm completely stuck on this?
