Electric Problem
20 Jun 2012
Polegate, East Sussex
Hey Guys,
We have an Electric Fireplace, went to turn it off and noticed it was quite warm on the built in wall socket. Couldn't get the switch to 'Off' either.
Have taken it off the wall by unscrewing it, which has turned it off. Just wanted to make sure this should be ok for tonight until we get someone out to look at it tommorow? Or am I going to wake up on fire?
Sorry for quality of picture, but yeah I have noticed the heat marks on it now as well. I also took the fuse cover off to try and get at that first but decided this would be a safer option as I only have metal things to try and prise the fuse out.
Is it safe to get the fuse out? Seeing as I cannot switch the switch to off, whenever I press it against the wall it all turns on, but leaving it as it is means it is all switched off.
I have undone the screws on either side and pulled it slightly away from the wall which has turned it off.
Personally i would Turn the main power off for the house at the fuse board as you cannot switch it off then remove the fuse so it is safe and power the fuse back on
Ok guys will do as above. Got to charge my phone up first so I can use the flashlight on that, then give this a go! Should be asleep now! Bah Humbug.
Well I managed to get the fuse out, looks to be fine itself. Will contact the landlord tommorow and see whats going on. Thanks for the advice, can sleep safely now!
As above, will be a loose connection thats causing the heat. With luck there is enough wire back there to cut it back and make a new one to a new switch.
Its probably been like that quite a while.
get the landlord on it straight away, and make sure its a qualified electrician that does the work.
There's heat damage to the socket and the fuse didn't blow?
As PhillyDee said a loose connection that is arching will not activate/blow an overload circuit (MCB/Cartridge or rewireable fuse) it won't even activate an RCD/RCBO!
Obviously though if it arcs to ground or Neutral then MCB/fuse's will blow and RCD/RCBO's would activate.
Arching loose connections are one of the number one cause's of electrical fires which is why you should always double over your terminations and make sure they are mechanically secure.
/16 Ed. :D
