- 25 Sep 2012
- Scotland
I am having a problem where if I touch some of the screws on my metal computer case I am getting quite an uncomfortable electric shock. It isn't like a static shock but more like a continuous current. The screws that give me the shock tend to be the ones nearest the power supply.
My power supply is a Corsair RM650 fully modular unit which was bought brand new in November last year.
I have stripped the PC down to make sure the motherboard standoffs are correct, I have inspected all the cables for bare wire, I have checked for any pinched cables and I made sure to plug the PC directly into a wall socket rather than an extension lead. I also tried two separate wall sockets.
Still getting the shocks.
Is it likely to be a bad PSU or is there something else I should check?
This PSU replaced an old superflower that I had for close to 10 years without issue.
Thanks.
Thanks.
