Electric showers
1 Dec 2006
Evening all
Quick question as i have noticed that since we have had good weather my electric shower (10kw no pump) is performing much better, meaning that i can turn the temp setting down giving better flow rate. The only reason i can come up with is the higher ambient temps of the mains.
So with this in mind can i add a hot water supply to my electric shower using a solonoid valve fed from the shower output just to bring the average temp up slightly? I would think that a one way valve would be required to stop the mains pressure "back filling" the hot water system so i guess my question is do one way valves work on the the pressure differential placed upon them so if the mains was at a higher pressure it would not allow the hot water into the shower?
Just reading the post back and thinking about it seems its a non starter but worth the question?
TL: DR
Can I add hot water to my electric show even though the pressures are very different
not really because the pressures are so different, I could put in a pump set to try and balance them but they are quite expensive and noisy
A simple solonoid and oneway valve is about £20 and a pump set about £150-200, its not a really big deal but i just thought if i could improve the showers performance by adding a bit of hot water while i have the plumbing exposed it would make sense
Edit: I live in a flat so the water tank feeding the hotwater system is at a fairly low level meaning low hot water pressures compaired to mains
I don't think you are allowed to feed water into a mains connection? Say if the mains pressure dropped, you'd be supplying hot water back into the system.
But like you mentioned, faced with a higher mains pressure, your feed isn't going anywhere.
The normal way to get better flow rate is to use a tank and a pump.
No no no, definitely don't do that, it could go wrong in so many ways man.
Do it properly or don't do it at all.
TBH i dont think i am going to do it purely for the reason that to be compliant it is going to need two check (one way) valves, and i dont think this would work with the pressure difference
But out of curiousity could you name a few of the many ways this could go wrong?
Cheers
Looking to replace a shower here, been looking at the Mira Platinum Digital Wireless Mixer Shower.
Available for Mains Pressure Combination Boiler Or Mains Pressure Unvented
systems, I just like the wireless controller.
Sort of a hijack but hopefully on topic enough, this house I've just bought has a brand new but non-combi boiler and the hot water pressure as you'd expect is pretty low, with the shower (essentially just an attachment on the bath taps) being the worst.
I really don't want to go electric but I also don't want to go to the expense of something like the Mira Nightglow suggested and still end up with no pressure.
Hi lopez
You can go 2 ways
Thermostatic shower + pump or
that Mira shower that Nightglow listed but the pumped version.
