Electric window problem
2 Dec 2004
Under The Desk, Wales
I have a Megane (Funny back one) and the passenger window does not work. The button on the door for the window and the one on the drivers side do not work for that window.
I have checked the fuses and they are fine. Could it be the motor? No idea where to start!
If you've checked the obvious then you'll have to pull the door card to firstly check that the connection to the motor hasn't for some reason come off, check to see if there are volts coming to connection and lastly check the motor itself.
