- 28 Jul 2003
- South Wales
I need some help tidying up a switch setup. We have just had our bathroom re-fitted. The single light was replaced with 4 spots which run off the same ring the old one did. The pull string switch has been replaced with a single switch outside the room (it's a small ensuite so no biggy).
We have also had some small LED's put in the wall of the shower. These are 12v and run off a switched fused spur.
My problem is i hate the fact i have two single box switches. I asked if the two could be replaced with a single box, double switch setup but it seems it can't. (Not had the official reason yet but will post back when i do, i suspect it's down to different voltages maybe?).
Is there anyway i can reduce the two switch boxes to one. I don't mind if it's all on the same switch but really want a single switch box solution.
any advice appreciated!
