So this weekend mini project was installing a ceiling fan - not really messed around with a ceiling light before beyond changing the bulb, but I did the appropriate research and it all went reasonably well.
The problem I now have is that the fan was not designed to have a light switch in the mix - its a standard 9 wire job coming out the ceiling, so I have the 6 "circuit" wires going straight into the fans connectors, with the 3 wires from the switch taped up and unused.
I understand how the old ceiling rose works, so I know I could in theory connect up the fan and the wall switch using a similar set-up, however its designed to be mounted on the ceiling, not above it. I assume there is some kind of junction box designed to do the same job that can be pushed up into the ceiling, but I don't know what its called, so have not been able to successfully google it.
tl;dr - Need a box that takes in 9 ceiling wires, and spits out a live, neutral and earth, all controlled by the wall switch, that lives in the ceiling cavity.
