- 22 Sep 2016
Hi there,
I have put this question in GD as I guess it is more of a general electrical question than a specific unique to 'Product XYZ'.
So a couple months ago, my Macbook Pro magsafe cable split open in multiple locations along the wire (the part from the brick to the connector that goes into the computer --- the part that can't be replaced basically!). I bought a new one for my every day use but I was miffed to say the least at having to spend £80 on a new charger after less than 3 years of use.
So after doing some reading online, I came to what I felt was an educated conclusion that I could wrap electrical tape around the split parts and all should be good. It was only the white plastic sheath that had split and there was the silver strands exposed but unbroken (that I am now led to believe are grounding wires?).
So what I did in an effort to try and stop the plastic sheathing from splitting any more and try and get some use out of the power cable as a secondary power source when I use my Macbook at my desk was just to wrap the entire cable in thick black electrical tape.
I have been using the cable for a couple of months now and it works.. and I have not been electrocuted, but I have just watched something on Youtube that has kind of made me doubt that what I have done is safe. If the exposed silver strands inside the cable touch the electrical tape... would that conduct electricity and cause a shock?
Sorry if this sounds dumb. Any thoughts welcomed!. Thanks
