Hi,
looking into the possibilty of running some lights of a 12v car battery and charging the battery with solar power.
the load will be 100w which if i've done my sum's right comes out at just under.5 of an amp ( 100/240 ).
The ligths will be on for between 3-6 hours, what wattage solar panel would i need to be able to keep the battery topped up and useable.
cheers for any info
deano
cheers for any info
deano
