Hi,
I've replaced the hall and landing lights in the last 2 days as well as switches.
Each light takes 3 x G9 led bulb.
I initially replaced the downstairs light in the hall and the switch. It's a 2 way switch in that it controls the hall and the upstairs landing light. Took the old light down, connected it all up matching wires/locations and it all worked great. lots of light.
Just done the upstairs light and followed the same as the downstairs, added the bulbs and they are lit. hit the old switch and they light up properly. Changed the switch just in case and even with the new switch I have the same issue.
Checked the wires, all look good, well connected.
So, the downstairs lights are off or on.
Upstairs lights are either very dim and on. They don't go off.
Any suggestions?
Amazon review of the bulbs say that other people have had this but no answer on why, they blame the bulbs. But, I find it doubtful out of a pack of 6 I just happened to pick the 3 that go off for downstairs and those that stay on upstairs.
Any suggestions?
