Hello...back in a different sub-forum with the same problem.
I got an RMA for my mobo to check if it was generating dodgy sound and got my mobo back no fault found.
My situation is when playing games, not even necessarily high GPU load games, I get interference in my sound output. It sounds like static electricity, or sometimes like an electrical substation.
Example of sound here. It seems it starts by having a sound from the game that sounds kind of like interference (like a rocket taking off) and then decides that's part of the sound for ever more.
www.icloud.com
I have an X670E Pro RS. I have issues with two different sound devices (one 3.5mm jack, and any my USB headset), and three sound outputs (HDMI through graphics card, onboard graphics through 3.5mm audio jack and sound blaster x through 3.5mm headphone jack).
I want to test if using the SPDIF out of my soundcard can break this problem by hopefully taking a pure digital signal minus noise along a fibre to a seperate DAC and then converting it to an analog signal without the noise presumably being generated by my Graphics Card / MOBO / CPU AIO / RAM / PSU / WiFi card.
Does this sound like a sane thing to test or should I save my money and bin my new rig?! If it does, I need to buy a DAC with an SPDIF input and a 3.5mm jack output (or headphone would do). I can see lots of sparky boxes on sale on Amazon for £10.00, but it can't be that simple right?
I also assume that the "noise" from whatever component or components are generating it travels along my HDMI/DisplayPort/USB/3.5mm jack wire and won't travel along the fiberoptic SPDIF cable...am I right or just talking rubbish?
iCloud Photos - Apple iCloud
View, organise, and share photos and videos with iCloud Photos on the web. Changes will sync across your devices with iCloud.
