- 18 Oct 2012
hi guys, i'm trying to reverse engineer a circuit which has a pair of transistors on it.
unfortunately in my testing i *may* have slightly over-volted the circuit to try and get a bit more kick out of it and i suspect the magic smoke that ensued might be from the transistors even though they look fine.
the markings on the side read thusly:
N:SD
965
72215
checking continuity i'm getting no resistance between any pair of legs so i think they're fried.
any ideas? google just gives me a bunch of generic links to shops selling transistors.
N:SD
965
72215
You can zap your enemies as well then...
) killed it
