Hi,
I'm hoping somebody could help with an electrical drain i've got on my MK1 Octavia VRS.
When my car is locked there's a draw of 210mA which is killing the battery in two or three days. I've left it locked for at least 20 mins and the same draw is still there even after all of the systems should have shut down:
I've isolated it to this wire. When it's pulled there is no current being drawn:
That's not too helpful because I have no idea how much stuff this wire powers. So to try and narrow it down some more i've tested the individual fuses in the fuse box at the drivers door:
In that picture i've taken Fuse 14 out (3rd in, 3rd down, from the top left) as this is the only one that seems to change the current draw. When that fuse is pulled I am getting a much more respectable 50mA total draw from the battery - although even that seems a little high:
I know this fuse is interior lights (of which none are switched on), but i'm not clear on what else it's doing. To dig a little deeper I tested the current for just this fuse. This is where i'm getting really confused. This fuse only draws a small 20mA. Although the total effect on the draw from the battery is 160mA:
So i'm a bit lost on what to do next, and this is annoying the hell out of me. If this fuse box isn't using the power then what the chuff is? Am I being daft and missing another fuse box or something?
Appreciate any help!
Cheers.
Anthony.
Cheers.
Anthony.
thats just made my morning
