- 2 Jan 2019
We had some work done in our kitchen/diner recently removing some internal cupboards/walls and putting bi-fold doors in. In our dining room we had a ceiling light which was controlled by 2 switches:
Switch A - on an internal wall on one side of the room which was a dimmer switch
Switch B - on other side of the room which was a simple on/off switch
We told the builder they could remove light switch A (the cupboard wall it was on was being removed) as we still had switch B at the other side of the room. Having capped the cable for switch A and plastering that into the ceiling where the cable came down from, switch B no longer works.
What could they have they done to stop switch B from working? Is this an easy fix - what would it involve?
TIA
TIA
