Hi all
I was wondering if there is a compliant / legal way of getting another electrical supply out of the main meter (in utility cupboard outside) as opposed to running a new circuit from the consumer unit (indoors). The new supply will be for an outbuilding.
Please see attached photo below. The cable connected to the meter is naturally the one that is currently feeding my consumer unit, there are no other spare ways on this meter and it would be a major hassle to run a new circuit from the consumer unit.
I was wondering if the following is possible
1) Install a new connection box (product / spec unknown) in the utility cupboard, sufficient to allow an incoming feed and 2x 3core outgoing cable connections.
2) Disconnect existing consumer unit supply.
3) Connect meter to the new connection box
4) reconnect the consumer unit supply to the new connection box
5) Connect the new cable to the connection box.
Or would I need to get the utility supplier to provide a new meter with additional outgoing terminals?? However I note the earth core bypasses the meter.
I will obviously call in an electrician to do the work, just want to get my ideas straight before approaching someone.
Thanks
Thanks
