Electrical short caused buzzer/speaker cable to melt?
5 Feb 2023
Cornwall
My chassis has a front panel buzzer, it's not a true speaker - just connects to the beeper on the motherboard.
Last night it melted, seemingly out of nowhere. Turned the PC on and smoke started pouring out. The only explanation I can come up with is that the buzzer cable was routed behind the motherboard tray, and was somewhat pinched by the chassis panel; it's possible that it had frayed and deteriorated each time I'd removed the side panel which degraded the insulation and potentially exposed copper.
I'm not really sure how a short on a 3.3v header can cause the wire to overheat like this.
This is the only possible explanation I can come up with. Anybody else care to chime in? This was the only symptom, the PC continues to work fine. Thanks.
The voltage is enough, modern torches use 3V leds and lithium batteries easily push 3A+ through them which causes a fair bit of warming.
Looks like the positive wire insulation roasted off but not the black wire so I'm guessing it didn't short the header across itself but shorted the + into the metal case which may have bypassed usual current limitation on the header? Or maybe a tweeter header always did have enough current to melt insulation if shorted.
Thanks. Really appreciate this. Fair shout abou the 3V LED torches, I guess the 3.3V really was enough for the meltdown, especially in the event of a short where the current was allowed to do its thing.
I think it must be a short because that header is only normally powered for a split second when it is beeping. The magic smoke happened just after the computer came on, I don't think there was a POST beep, just fire.
The other thing I can't rule out is a goofy motherboard; this is a Socket 370 build from 1999; so there's that. I may test it with one of those basic motherboard buzzers you get free with PC cases, I have plenty of them hanging around. If they start burning in the absence of an obvious frayed cable, then it's time to retire the board.
