Electrical work at home
5 Nov 2010
Hertfordshire
Just had some electrics sorted by an electrician on the street.
Do i need a certificate for the work (new light, sockets, kitchen re-cabled etc)?
If so, what do i need and why?
Depends on what work was actually done, but sounds like you should be expecting either an electrical installation certificate or minor works cert and possibly a part p compliance cert.
ps. What does spark on the street mean, if its a bloke you know or neighbour, maybe he isn't expecting to cert his work as he did it for mate rates or as a favour not a 'real' job with certs etc
He's a spark and has done it "mates rates".
He's put in new lights and re-fixed kitchen electrics, replaced switches and sockets.
Do I need certificates for electrical work? I can't fin anything that's days I have to and what for exactly. Only that it might come up if/when I sell the place.
"re-fixed kitchen electrics" what does this mean?
Don't take my word for it, but lights, switches and sockets you should be ok with as they are cosmetic things and not major.
The previous owners though it was a good idea to put sockets in the lower cupboards (even under the sink) to plug in appliances etc. the cooker switch was in a cupboard instead of above the work surface. Also, the cables were just left laying on the floor.
I got the electrician to mount socket properly behind appliances and on walls above the surface, with switches as well as a new cooker switch. All cables now tidy a tacked or trunked.
It is a good idea to have them in the cupboards imo, or have switch above the worktop that turns the sockets off below. I opted for the cupboard way after seeing a washer/dryer combo nearly burn a place down.
Nothing wrong with a socket under a sink either i dont think, certainly better than stuck behind a washer.
I do not think that live sockets in the cupboard under the sink is a good idea, where there is most likely to be a large leak/spill of water.
Nor do i think it's wise to have a cooker switch in a cupboard, in fact, i thought it had to legally be above counter.
The sockets were mounted on the flimsy back board of the cupboards. Not exactly a wise installation. There are now sockets mounted properly in the wall behind the appliances with switch above the counter. Which is and should be the norm.
And THAT Boys n Girls is the whole point of Part P!
It is actually a fiscal strategy dressed up as a safety one!
The whole point is to intimidate home owners into demanding traceable paperwork so that it is more difficult for Electricians/customers to make cash in hand arrangements for small jobs! (And also to intimidate potential DIYers into having to spend money on employing electricians, also boosting the tax take)
should be ok without any certificate. Ive change the lights and sockets in our flat. But ill be putting the lights back (pendants) when we move out.
I would say if the work was for things outside of special locations, such as, kitchens and bathrooms and did not involve a new circuit or the replacement of the consumer unit then it would be fine as far as Part P is concerned.
http://www.planningportal.gov.uk/uploads/br/BR_PDF_AD_P_2013.pdf
Not sure though whether you still require some sort of certificate from an electrician for non notifiable works?
