I have a question I'm hoping an electrician may be able to answer. A few hours ago I went to turn on my cooker hoods light and a bulb blew and flipped the circuit breaker that it's on. I replaced the bulbs with spares I had from the last time it happened and reset the circuit breaker but the lights and fan of the cooker hood don't work.
All other sockets in the kitchen work, and the switch that the cooker hood is wired into I've checked the fuse with a multimeter and that still has conductivity so isn't blown, and I couldn't see any sort of fuse in the cooker hood itself.
The cooker hood is a Caple model F3 60 INOX SL. The only manual I could find only was a stupid 2 page PDF of a photo of the manual (which I don't seem to have myself) and only talks about things like washing the metal filter, and replacing the carbon filter etc... no info on what to do if it completely stops working after a blown bulb.
So if anyone has any clue as to what the problem might be and any way to solve I would appreciate it. Thanks.
