- 18 Jan 2008
- Fleet
Hi, Hoping there is an electrician in here
Wondering what would be the best way to install a plug sock in the loft just need it to plug a network switch which will power several ipcams (POE). 13 Amp socket max, Would it be all right to take power from the lighting circuit.
Cheers
Wondering what would be the best way to install a plug sock in the loft just need it to plug a network switch which will power several ipcams (POE). 13 Amp socket max, Would it be all right to take power from the lighting circuit.Cheers
