I was wondering why the min psu requirements are now around
the 500 watt mark seeing as tft use less power the core 2 duo uses less power
it can't purely be the graphics cards can it?Am i missing something?
has anyone even tested a core 2 duo with say a 350 watt power supply
and 16x pci express?everything seems to be using less power yet the power supply requirements seem to be going up and up.I've done some calculations
and this means your average pci express card uses 200 watts of power?
edit monitor runs off it's own power doh ! but what about the cpu using less volts and power?
), the distribution of power on the rails is not necessarily where you want it, modern PCs draw most of their juice from the +12v rails (particularly graphics cards, which are the biggest culprit in most of our PCs) and older/crappier PSUs can't deal with this (having either poor stability/performance or inappropriately distributed load). There is a vast difference between a decent quality 400 Watt PSU and some generic tat that came with a £15 case/PSU bundle (but manufacturer estimates rarely make any distinction).
