- 22 Feb 2014
We currently have the main CU under our stairs and the kitchen socket circuit is separated on its own MCB(32a) on this circuit is a fused switch spur (13a) which runs via 2.5mm armoured cable to the shed where it connects to a separate CU, the sockets in the shed are all connected to their own MCB (16a)
both mcbs on this circuit are "b" type
The situation is this, a repairman came out to fix a faulty tumble dryer in the shed and he turned it on to test once he had fixed it, however our working tumble dryer was also switched on at the time.
as a rough calculation I expect this put somewhere around 20 - 24a load on the circuit.
What I would have expected to happen was either the fuse or one of the MCBs to trip. however what actually happened was some plastic in the fused switch spur melted and broke the circuit, then when I came to try and fault find and turned the switch on/off it was arcing because of the melted plastic preventing the switch from making proper contact.
My question is
what should I change in this circuit to ensure it trips in future whilst still allowing me to run a single tumble dryer in the shed and any power tool I might need to use.
My question is
