electriQ 27QHD180I 27
8 Sep 2008
I'm on the lookout for a semi-decent dual monitor setup. I'm not looking for anything high end just decent picture quality and be good for gaming and work.
So I came across this: electriQ 27QHD180I 27" IPS QHD 180Hz 1ms Gaming Monitor for only £120. How can a monitor with that spec be so cheap?
I can get a full dual monitor setup with Gaming Dual Monitor Arm for £300!
Has anyone tried this monitor, whats it like and will it work as dual setup?
Hi, I have had this monitor for around 6 months and its brilliant best 180hz monitor I've ever owned!
Very Smooth to play games on and nice to watch videos and films on!
"Will it work as dual setup?"
Absoloutely I run two and haven't had any problems with either.
Hope this helps.
Yeah I ended up getting two plus a duel arm for £279.98! Both came in perfect condition, no dead pixels or anything. There is very slight difference in the colours between the two so I am going to get a used Spyder colour meter and calibrate them.
Great value and perfectly fine monitors for general use and gaming.
