Electromigration when pushing higher then stock VCORE
Man of Honour
20 Sep 2006
Is this something to get worried about? How bad does it affect the processor and how high should the voltage be pushed? CPU is E4300.
Providing the temps are kept down, what's the highest VCORE I should go if I want the chip to last?
By the time electromigration becomes a problem your CPU will be obsolete. I wouldn't worry about it.
As for voltages, on air I wouldn't go much above 1.45v.
