Electronic Fan Controllers
24 Oct 2002
Bucks and Edinburgh
I am in the process of getting the bits together to remove my viscous coupled fan and standard radiator and fit a larger radiator and electric fan kit.
I've got the radiator and am looking at a pair of 12" Kenlowes/Pacet/SPALs. What Im having difficulty in finding is a high quality electronic fan controller. I would like the controller to be dual speed/stage so it cuts in at a low set temp and kicks in a full speed when it gets to the higher set temp point. It will need a relay as it will drive two 12" fans and would like the sensor to be able to fit on the top rad hose using samcos so it will be like a joiner.
I sure such a thing exists but I cant seem to find it, so has anyone actually come across one ??
Also would an override switch be a good idea or not really necessary. Cheers.
Look at burton power, they supply anything you could ever need. Sure I remember seeing something along these lines in this years catalogue.
