- 11 Sep 2009
- France, Alsace
I recently just completed a mini build of turning an old champagne box into a bluetooth powered speaker. I'm fairly useless at electronics, but this was really simple and it sounds really good to be fair.
It simply uses tweeter - bass driver - crossover - bluetooth amp board - micro USB connection out the back.
You plug in the micro USB and power comes on. I would like to take this the step further and have a pack of rechargeable batteries in the speaker, an off off switch and the micro USB would be used to charge the batteries.
Was looking at replacing my little micro USB board with this one:
Then having the output going to the bluetooth board, but with a switch wired into that + and would like a battery pack running off this but I don't know what to use for it? I want it to last a bit of time between charges, but unsure what sort of battery I should use?
I see these AA battery holders with 2-6 batteries in there but how long would it last?
If it helps the bluetooth amp is this one:
https://www.amazon.co.uk/TPA3116-Di...amp+board&qid=1591617290&s=electronics&sr=1-5
I know there are some great electronic tinkerers on here so thought I'd ask!
Fanks!
Fanks!
