Hi,
I have a REL Strata Subwoofer, from quite a while ago. Anyway the thing now pops at low freq and loud scenes.
I called REL up and they said its a resistor on the circuit board that's gone and this is a common problem. However they want a tidy sum to fix it.
I'm no electronics whizz, but I've done small amounts of soldering in the past. I can easily remove the amplifier board out of this sub...However I have no idea how to find the culprit. There's a load of resistors on this board. So to all you budding electronics whizz's. How can I find which resistor is at fault, so that I can un-solder it and re-solder in an exact replacement? Is this something that would need just a simple tool to diagnose? Or does it require inside know how of which resistor does what? Failing REL, do you reckon any electronics TV repair service as such would be able to diagnose and repair? I've rather not send my circuit board halfway around the world.
Please advise.
Please advise.
