Hi all,
I've got an Optoma HD700X projector, a Sony BluRay player and a Cambride Audio 640Av2 amp.
Connecting from Sky box -> amp and PC -> amp both seem fine (using monitor/TV as display).
When the projector is attached to the BluRay player and then the BluRay player is attached to the amp I get a very annoying mains hum. Removing the HDMI cable from the projector gets rid of the hum. I get the same issue with component to the projector.
Removing the earth from the power strip that goes to the projector seems to reduce but not eliminate the hum, but this is not a solution for the obvious safety issue (and the fact the problem still remains, albeit to a slightly lesser extent)
I've tried plugging the projector into the same 4 way extension as the player and also tried plugging them into separate wall sockets but the problem is the same both ways round.
So, question is, is there an affordable and safe way of sorting out this issue?
