elite doubts?
18 Feb 2007
London
hi
ive just got a hd dvd addon for my premium , and was eventually going to upgrade to an elite also, but after reading the artical on eurogamer about not being a lot different (console and picture quality using hdmi).
im starting to think is it worth upgrading , perhaps i should be happy with my premium and hd drive?
perhaps i should just wait now until i get a new console and see what wins the hd/br format war.
cheers
Wait. Not worth the extra cash for next to nothing. Unless you need the harddrive space, but you can buy the Harddrives for £75.
I dunno, havent looked as ive had my premium since launch. Have a look around. Guessing maybe £230 or something around that area.
IMO HDMI offers no significant picture quality over an analogue connection.
It boils down to the old Digital Vs. Analogue debate. I stick by analogue myself. In music analogue is far superior and i would go as far to say my VGA connection on my 360 is superior picture quality to HDMI.
Josh
Id hold off, saw an elite in London the other day, its obviously down to preference but I thought it looked cheaper and more plasticky..especially the pad.
Don't buy the 120GB HDD in this country its ridiculously overpriced, import for the win!!
Can be had for approx £100 in canada ;)
That shows thermal pads under the heatsink. Mine doesnt have them. No wonder mine crashes.
Ill have to get some to see if it makes a difference.
Josh
I have had mine for 10 days now and not had a crash yet touch wood.
Its also not as noisy as my old core system.
You can just hear a faint humming noise from the fans.
Also the benq dvd drive is not as noisy when playing games.
Josh
Going slightly off topic, analogue actually is able to contain far more information than information stored digitally and our only problem at the moment is how to utilise analogue effectively.
I think this is shown in music where analogue music is much more clearly defined than digital music.
Digital v Analogue.
As a technology, analog is the process of taking an audio or video signal (in most cases, the human voice) and translating it into electronic pulses. Digital on the other hand is breaking the signal into a binary format where the audio or video data is represented by a series of "1"s and "0"s. Simple enough when it's the device—analog or digital phone, fax, modem, or likewise—that does all the converting for you.
Is one technology better than the other? Analog technology has been around for decades. It's not that complicated a concept and it's fairly inexpensive to use. That's why we can buy a $20 telephone or watch a few TV stations with the use of a well-placed antenna. The trouble is, analog signals have size limitations as to how much data they can carry. So with our $20 phones and inexpensive TVs, we only get so much.
Enter digital
The newer of the two, digital technology breaks your voice (or television) signal into binary code—a series of 1s and 0s—transfers it to the other end where another device (phone, modem or TV) takes all the numbers and reassembles them into the original signal. The beauty of digital is that it knows what it should be when it reaches the end of the transmission. That way, it can correct any errors that may have occurred in the data transfer. What does all that mean to you? Clarity. In most cases, you'll get distortion-free conversations and clearer TV pictures.
You'll get more, too. The nature of digital technology allows it to cram lots of those 1s and 0s together into the same space an analog signal uses. Like your button-rich phone at work or your 200-plus digital cable service, that means more features can be crammed into the digital signal.
Done a bit of looking, it seems the Premium works out cheaper than a Core+HDD.
Core @£179.99 + 20GB HDD @£64.99 = £244.98
Premium: £229.99
