13 Feb 2006 at 22:19 #1 Stinky Stinky Soldato Joined 28 Mar 2005 Posts 9,217 hi all i have just had to reinstall Windows XP on this for my grandad. just wondering what motherbored it has. he is saying its slightly slow. so wanted to try clocking the CPU up but there is no option to in the bios. any ideas??
13 Feb 2006 at 22:22 #2 lemonkettaz lemonkettaz Soldato Joined 28 Nov 2005 Posts 12,993 probably a standard BOG3000XXX EXTREME wood edition.
13 Feb 2006 at 22:30 #3 Stinky Stinky Soldato OP Joined 28 Mar 2005 Posts 9,217 your being sarcastic???? i googled it still
13 Feb 2006 at 22:43 #4 lemonkettaz lemonkettaz Soldato Joined 28 Nov 2005 Posts 12,993 im being sarcastic no idea what board it would have... doubt you could get more performance from it though
14 Feb 2006 at 00:25 #5 nikebee nikebee Soldato Joined 9 Nov 2004 Posts 13,984 Location Pembrokeshire you could stick something like CPUz or Sandra on it, these both should be able to tell you what the motherboard make/model is
14 Feb 2006 at 02:48 #6 lay-z-boy lay-z-boy Soldato Joined 27 Sep 2004 Posts 9,229 Location Nantwich its a no-name brand with no oc options avaliable, worked with a number of emachines pc's and they all run the same carp no-name mobo manuf.
14 Feb 2006 at 03:57 #7 davetherave2 davetherave2 Soldato Joined 27 Mar 2003 Posts 2,710 ok if you want some info check this link out for the emachine 2210 http://www.pcservicecall.co.uk/layout.aspx?ID={97b4cc73-267f-4577-926f-e1f25906e6ac}&CatID={c430b6b7-c353-4b7d-b6df-566b1c547865} This should give you all the info that you need. If you need more info give me a shout. After just taking a quick look at the specs it may be worth just upgrading the ram given that it only comes with 128MB. Last edited: 14 Feb 2006
