Emacs question
Try putting the following in your .emacs file:
[FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1] ;; do not make backup files
(setq make-backup-files nil)
source: here
alternatively it looks like you can have Emacs store them all centrally:
[/SIZE][/FONT] ;; ========== Place Backup Files in Specific Directory ==========
;; Enable backup files.
(setq make-backup-files t)
;; Enable versioning with default values (keep five last versions, I think!)
(setq version-control t)
;; Save all backup file in this directory.
(setq backup-directory-alist (quote ((".*" . "~/.emacs_backups/"))))
source: here
(both sources have other customisations to)
